51 cub hydrallic system
Tom Durrer
have slow fluid leak in my hydrallic system. I think
it is the O rings. The fluid leaks out over a few days time. If I add more fluid everything is fine.
Could it be anything else? How hard is it to
pull the hydrallic system and change all the O rings and rubber boots.
Tom
Is the fluid leaking out on the ground, or just disappearing?
If it is disappearing, check your engine oil level. The most common failure is the O-rings in the hydraulic pump, causing the hydraulic oil to end up in the crankcase.
I didn't think it was that hard when I took mine apart, but then again I grew up on a farm and had some wrenching experience.
If you aren't good at remembering where things go, take LOTS of pictures.
Work in a CLEAN area, with lots of CLEAN rags on hand.
