51 G Wiring
MDM
I have found a 12 volt generator with regulator and have had it rebuilt, does anyone have a diagram showing where all the terminals should be wired to? Should this be positive or negitive ground?
Check in over at the JD-H Restoration Site (below). Scan across to ARTICLES 2. From the drop-downs, select WIRING DIAGRAMS 3, and then follow the string down to JD-G. You can print the two-page document -- should be clear enough. (PatB)
Restoration Site, JD H
