used red MN
- Location
- Coon Rapids, MN
Nope, the diode is shown in the circuit to the “1” spade terminal of the alternator as shown in the linked generic 12 volt conversion wiring diagram. A warning lamp or resistor can also be placed there. Its purpose is to not allow enough current to backfeed from the alternator’s excite circuit to fire the coil and keep the engine from continuing to run when the switch is turned off. When a lamp is used when you turn the switch off the light starts glowing until the engine stops due to the bulb has a higher resistance than the ignition coil. Hope you can understand that. The resistor in your picture is shown in the diagram in green, it has nothing to do with the charging system it drops the voltage to the coil.Is this what you are talking about?
Generic 6 to 12v alt. wiring diagram
Edit to add: The question still remains is there an alternator on your tractor or a 12 volt generator? Photo?
