5100M ground speed sensor
Can anyone tell me the location of the ground speed sensor on a John Deere 5100M? The JD parts.com website only calls out "sensor" for all sensors with no detail as to what Any of the sensors do. I called my local JD dealership's parts department and the salesman couldn't find it. He put me on hold and went to talk with someone in the service department. He came back and told me that he thought it was the top shaft sensor. I don't have a high level of confidence that this is correct.
I located this sensor(key 22 RE330847) labeled wheel speed sensor in PC
13353 - 5100MH Tractor, OOS (1LV5100MHJ100001- ), Cab (1LV5100MHJ400001- )(North America Edition) - 27Sep17 ( FR ES )
Thanks Jim but unfortunately my tractor is the newer final tier 4 emission version and it doesn't have the sensor you found. You got my hopes
up and as soon as I saw your post, I went to look at the tractor. Just as my luck would run I'm just a few months out of warranty. I appreciate
you taking the time to try and find it for me.
You're welcome. My knowledge of JD tractors built after '93 is very limited but I do understand JD parts system. What is your tractors serial number & type of trans?
