Ben Hastings
I"ve gone through and replaced all of the wiring, voltage regulator, distributor cap, rotor, plugs, wires and the tractor ran fine all last summer.
Towards the end of the fall (when it started cooling off) I had trouble starting. I checked and the battery was drained. I may have a faulty ammeter on the dash, and I just picked up a hand-held multi-meter to test, but I"m not getting the engine to start (cranks, sparks, but no ignition i.e. not running).
My guess is there is something wrong with the generator, but I"m not quite sure how to go about testing it and I don"t want to replace it if it"s not necessary.
This is all original or OEM 6v (I used the hotter autolite spark plugs - everything else is spec).
Any help is appreciated.
