52 8N governor
r48r50a77
52 8N governor gear or what drives the cable on the proof meter is worn it seems. The meter works and the cable looks good and drives meter off a small drill so it seems the problem is within the governor. The kits are not in stock. How do I start with this repair? Thanks.
Tach drive cable should have a "tang" sticking out that engages with a slot in a "roll pin" driven into the hole in the back of the governor shaft.
Tang may be worn off or rollpin may not be installed.
If I remember correctly, this cable end is SIMILAR the what an "N" would use at the gov end.
<img src = "http://www.jalopyjournal.com/forum/attachments/004-jpg.1206656/">
