'52 8N Loader Install/Removal
cabisson
Hey all,
I've got a 1952 8N that I've owned for about a year, with a Ford I9-II7/Model 68 Industrial loader on it. I'd like to do some engine and body work/restoration before the snow starts to fly again, but doing anything up front with the loader on it has been severely hampering my efforts (read: getting nothing done at all).
I haven't been able to find anything regarding the installation/removal process of the loader, shy of a couple vague "Email me and I'll tell you all about it" posts in various forums.
I know it's not going to be a "quick and painless" process - but I'd like to keep it at a "weekend without stitches" point.
I know where all the disconnect points are, but actually getting it off the tractor is where I'm stalled. To me, it looks like I'm going to have to build a lift cradle around the whole thing, back out of the loader a little ways, then lift it up and over the front wheels. Bit of a PITA, but doable. But, I'd like other folks' input and suggestions! Pictures would be even better, if someone has documented a step by step!
Thanks in advance!
I have not removed that model loader but have removed a good number of them over the years. An A frame or a good big tree with a good strong limb works real good for removing loader. A nice chain hoist is also a big help but a com-a-long will work also
(quoted from post at 17:23:33 08/02/15) Hey all,
Thanks in advance!
Probably just a chain hoist with enough lift to get the rear of the loader clear of the tractor. No need to raise the bucket end - just the rear portion of the subframe enough you can roll the tractor back out from under.
TOH
I agree with old... a couple of posts and a crossbeam of adequate strength makes it EASY.
Here's a photo of a lighter, narrower setup found on the 'net to hold a PHD.
Loader "stand" would be similar, just wider and a bit stronger.
You just need enough height and two small chain hoists or come-alongs to hold up the loader at the back of the "arms" while you roll the tractor backwards, out from under it.
<img src = "http://www.orangetractortalks.com/forums/attachment.php?attachmentid=4100&d=1317411208">
I used a engine hoist to remove my 19-61 loader this spring but then I had to move FEL away from tractor instead of tractor from FEL.
I will make a A-frame when I put back on.
I've removed mine a few times with just a Handyman jack, 4"X4"X8' board and some cement blocks. Not hard to do. Like TOH said, you only
have to raise the back.
like said, it really is that easy.
gantry, tree, to lift the back, undo some bolts and lines, roll the tractor back, and it's off.
tip.....a loader [i:a4e2ebc4c7]off[/i:a4e2ebc4c7] the tractor is a awkward, heavy beast...that is always in the way....
Drop the bucket off before you start, replace it with some cast iron weight plates and pins. Chain the lift arms to the loader frame.
set the rear down on a big pallet when you remove it.
Pallet forks will then drag it around.
Handy way to get them on trailers too.
like this....
