52 8n water pump
sunnyboy
do i need to take the hood off the tractor to replace the water pump, looks like it would be ok to do that. thanks
I pulled the old pump on my Jubilee to replace it and did not pull the hood. I suspect the 8N can also have the pump replaced without pulling the hood. Need to be careful that you don't put the fan through the radiator.
Last year just as we were use the 8N to prepare the ground with a box blade to build a house, the water pump started to leak. it was about 3:30 in the afternoon and I started to take to old water pump off, I sent my wife to the Ford Tractor place 40 miles away to get a new water pump. By the time she got back I had the old one off. I was surprised all the bolts came our easily and nothing broke off. I have heard several horror stories about changing water pumps on the N's.
I did not want to take the hood off, just because. It took several hours to complete but it worked and I had the dirt work done before the trucks arived.
I did one of mine last year - not a big job at all. As Gaspump says take the fan off first, then the water pump and put the fan back on after installing the water pump.
If you have a fan shroud remove the hood and radiator,,, much as I like to werk around stuff I as soon remove the hood
Things nice to have on hand
2 radiator mounting bolts
2 radiator mounting pads
upper radiator pad
Thermostat
radiator hoses
hose clamps
belt
Cheap as they are ,,,, water pump to backing plate gasket and backing plate to block gasket,,, never know when one is fudged up rite out of the box
Compare the water pump impeller again the old one,,, I have seen one impeller that was wrong on a N pump,, a nice thin coat of RTV will insure a good seal for the gaskets
