52 ford 8n not starting
bobvv
i have changed points, dist cap, rotor, condensor, plugs, wires, new gas, float is not stuck. i pulled the carb off. charged the battery and all it does is turn over. i pulled a plug to make sure im getting spark and i am. any suggestions to get this thing to start. it is 6 volt...and it is 30 degrees outside. do i need to convert it to 12 volt to get this to stop? it ran after it sat overnight in a 65 deg building....three hours after being outside it wouldnt start. thanks
do a compression test, but for time being will it start with a shot of carb cleaner, and be ready to choke it if it starts,
what color was your spark from your plugs blue and bright or wimpy and yellow,?
oh yea with all the work you just did on her have you double checked everything? when it did start was there any smoke, just thinking of some more ?s
Bob.......since you replaced the points, did you remember to "polish" the invisible corrosion off'n the points using a dollar bill??? Just 'cuz you pulled a plug and saw a sparkie, don't mean its a blue-snott HOT sparkie that will jump a 3/16" gap.
2nd, replace yer weak sister ignition switch. Secret cause of weak sparkies.
3rd, replace yer FLOODED sparkies with new clean dry sparkies. DON'T ARGUE!!! Recommend AutoLite 437's gapped 0.025". Don't throw yer FLOODED sparkies away, clean'n'dry them one-atta-time in HOT running engine and save them for the next time you have starting issues. And there will be a next time. ......Dell, yer self-appointed sparkie-meister
If you are sure you installed all the new parts correctly try jumping the starter with a 12 volt battery. To do this make sure tractor is OUT of gear. Turn key on. Find a good bare metal spot on frame or engine to ground one jumper from 12 volt battery. Hit the FRONT solenoid terminal with the other 12 volt jumper lead. Starter will spin as soon as it hits. Remove when engine starts or 15-30 seconds if it don't start. This way the 6 volt battery voltage is not pulled down by starting and the starter spins faster to compensate for low compression. If you get it running you still need to find out why it would not start.
Give it a good heavy shot of starting fluid into the intake or pull the intake tube off the carburetor and shoot directly into the carburetor throat. If it starts good then you know it is fuel problem and go from there.
Does the choke still have the little spring that holds the flap shut on the choke butterfly??? If not then it ain't choking!
Zane
Convert it to 12v? If you can't get it to run on 6v, what makes you think you can make it run on 12v? The problem isn't battery voltage; the problem is that you are just replacing parts w/o stopping to figure out if it is a spark or fuel problem.
There are three very important tools you always need to have in your N tool box: a 3 inch piece of wire w/ alligator clips on each end, an old spark plug w/ the gap opened to at least 3/16” ( ¼” is better) and a 7/16 box end wrench. And, you really do need a working ammeter. With these tools, you can quickly narrow down most N problems to spark or fuel.
First, check for fuel. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. If it’s a dribble, or runs for 5 seconds & stops, or none at all, you have solved half the problem: it’s fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good it’s not a fuel problem. So, next, crank the engine & look at the ammeter. What is the ammeter doing? Does it show a constant discharge, no movement at all, or does it dip? Next, get the old plug, ground it to a rust & paint free spot on the engine, turn the key on & crank the engine. If the spark jumps the 3/16” gap, you probably don’t have a spark problem. If it won’t jump the 3/16” gap, you have a spark problem. If the ammeter shows a constant discharge, or doesn’t move at all, that also tells you that you have a spark problem. Jump the ignition switch w/ your jumper wire & see what happens. If it runs, you found the problem. If it doesn’t have spark after you jump the ignition switch, then follow the volts. Do you have battery voltage across the points when they are open? Verify the gap on the points at .025. Then, run a new clean dollar bill through them. New points sometimes have a residue & old points can corrode, or get grease from the distributor cam on them. Or, you could have used a dirty feeler gauge. (I always spray mine off w/ contact cleaner.) Make sure you have voltage across the points, as in past the insulator on the side of the distributor. That is a very common failure point on sidemounts & often hard to find because it is usually an intermittent short. (If you find the short there, the Master Parts catalog lists everything you need on page 154. You can make the strip and you could also make the insulators as well. But, somethings are just easier & in the long run cheaper to buy. Get the strip, 12209, screw 350032-S, 12233 bushing & 12234 insulator & just replace it all.)If you just replaced the rotor & lost spark, put the old one back in. Check continuity on the secondary coil wire. Make sure it is firmly seated in both the cap & the coil. In fact, replace it temporarily w/ a plug wire.post back for more info on further troubleshooting.
If it does not have gas coming out of the carb at a steady stream w/ the bolt out, you have a fuel problem. First, remove the gas cap. Your vent could be clogged & it vacuum locked. If that doesn’t work, tap the carb bowl w/ a hammer handle in case the float is sticking closed. (don’t whack it w/ the head of the hammer; you can crack the bowl). If you still don’t see gas flowing, the N has three fuel screens; one in the brass elbow, one in the top of the sediment bowl & one on the stem of the sediment bowl in the gas tank. Check the screen in the elbow & the screen in the top of the sediment bowl. (don’t worry about the one in the tank) Both probably need to be cleaned. If you have the fuel knob turned on all the way, & 1 gallon or less in the tank, it may be trying to feed off of the reserve inlet which is probably clogged. Only open it 2 full turns. Put at least 2 gallons in the tank.
There are ways to check for spark & fuel that work & ways that don't. For example, having gas to the carb is nice, but having it past the float is what counts! That’s why removing the bolt in the bottom of the carb is the way to do it. And, same thing w/ spark at the plugs. Some folks think that checking for spark means pulling a plug wire off & looking for one. Well, it's the distance the spark jumps at the plug that gives you the info you want. It takes about 17kv to jump a 3/16" gap & 22kv to jump ¼” in the open air, so that's why you need to use a spark plug. Or, a store bought plug checker. Remember, it’s 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air creates electrical resistance, so you really need the 17-22kv to fire the plugs when the engine is running.
50 Tips
the spark was blue. there was no smoke when it ran...it actually ran good...revd up and ideled fine.
you had the correct answer. thanks. its a weak motor so im gonna upgrade to a 12 volt system. thanks again.
(quoted from post at 00:52:14 01/20/10) you had the correct answer. thanks. its a weak motor so im gonna upgrade to a 12 volt system. thanks again.
e sure and let us know the results.
