52 super A tranny fluid
Need to change the transmission fluid and both rear axle housings.
The operator manual list SAE90 for this . Can you guys please tell me what you are using for this
Thanks . Brian
The OM. the 90wt is a guideline. The two above are acceptable.If the primary use is in very hot temps,use 85/140. otherwise 80/90 is fine.
