520 Load Yoke Leaking Seal
The seal on my 520 load yoke is leaking. I have a manual many miles away, but I am sheltering in. I have studied the diagrams online and not found much in the archives. I know the bushings and the shaft may be worn out. I think you have to work under the lift cover and the shaft is removed through the side under the hydraulic line connection mount. I know the tension spring is hard to manage. Can anyone give me some pointers? Thanks
You need to almost completely gut the rockshaft compartment to replace that seal. One special tool is needed to make adjustments going back together, but it can be shop built. Better get a manual. Sometimes just greasing the shaft will almost stop the leak, there only atmospheric pressure on the seal.
