PushnFords
I'm working on a 520 and the power steering isn't quite right. I've gone through the system 100% so everything has been rebuilt. The worm gear is a late serial number version. When the tractor is first started it'll sometimes spin the wheels to full lock left OR right without touching the steering wheel. Also at idle on smooth concrete if you flip the steering wheel one direction or another it'll continue to turn to full lock by itself...and it'll do that going either direction. When driving it sometimes wants to follow the curve of the road...if the road is sloped it'll try to steer itself down hill. I don't think it is a problem with the centering valve adjustment because the problem is the same whether steering right or left. I backed the control valve adjustment stud all the way out but it still does it. There is a stack of washers inside the control valve that the book says adjusts steering effort so I'm wondering if I need to adjust though to make it steer harder? Are there other things I should check? When I took it apart none of the surfaces were in great shape but I polished everything up as good as I could and honed the control valve passages so the valves would slide smoothly. I'm using the JD P/S oil in it.
