520lp tractor help!
I need more help with finding what to do about a propane regulator for my 520lp tractor. I have been told that the Century M4 can be replaced by the century model H or M6. The problem is that they are not available because century is going out of business. I need to know which direction to go with a replacment regulator.
I Didn't know Century was going out of business but I used a Century model `H' in my 730 pretty much bolted up except for the fuel line had to be changed some. You might check with the forklift dealers in your area and see what they can do for you as far as getting you a regulator.
Tom
I know that Deerelydeparted.com were offering the Century a few months ago, but if it is as you say about Century they may no longer be doing so.... Maybe if you are lucky they will still have one on the shelf.
I replaced my 720 & "A" Century reg. with Impco brand & they are sold at any LP dealer or on E-Bay...the Model "E" will handle up to 450 ci. engine...Kent
I just got in a Century model H but it will not bolt up to my original bracket. I am going to have to build a mounting bracket to attach to the original bracket but it should work when I get it put on. Thanks for your help. I did find a local forklift repair shop that will make propane hoses and service the regulators.
