523387R11 IH Fast Hitch Filler Plate
Looking to purchase one pair of these filler plates. This is the 1/2" steel shim/plate that allows you to go from small 2 point to large 2 point. Couple different versions that I've seen on the internet are attached. Let me know if you have to sell or where I might buy a pair. Thank you.
They are easy to make. go to a local steel supplier and buy a strip of strap steel cut to length then cross drill for the retaining holes. Jim
Hello Dobo welcome to YT! Just measure the pockets
and get some flat bar the correct dimensions and weld
some ears on it like the lower picture shows. They do
not need the cross drilled pins at the front that just
keeps them from pulling out when unhooking. As long
as they are slid in there when hooking up an
implement, once hooked up they cannot come out.
