(quoted from post at 16:59:21 08/19/10) cavitation can/will kill a pump.
if he runs too high of viscosity of oil for a long time.. damage can occur.
I had to help a guy rebuild his hyd system after someone had him put 85/140 in it to 'help' it out.
ford listed the m4864 spec for the hyds in the manual and sae 80 mild ep oil in the tranny and diffy back then. if they wanted the heavy gear oil in the hyds the manual would have saved some paper and just shown it for all 3 IMHO. nford wasn't into waste..
soundguy
Not yet,,,, no complaints.... it does get colder than a witches t-i-t around here.... if i were to rebuild the pump it would get the thin chit,,, warranty purpose y'all got me skeered till then all the used worn out chit gets 80W90,,, the fluid is not his problem :!: ,,, I bet he would luv to get it primed even if it took the goofy chit....
On the one that gave me a fit I installed a know good pump,,, still a NO GO,,, had to pressurize the system to get it to pick/suck up the oil,,, I was at the point of standing the tractor on its nose are tap'n the suction side and force feed'n it...
Not disputing what has been said,,, so will leave it as do'n case study
:lol:
If you ever get inside one of these worn out trans and rear diff,,, it will seam impossible to keep cross contamination from happening,,, the original style seals are not available are the sleeves they run on either....
You have to use 2 seals instead of one and install 2 replacement seals were the original one went then face them in opposite directions from each other,,, sorta like in a marine application to keep water out and oil in....
