530 case Backhoe
So the other day I was going to run my backhoe, I usually have to go in reverse to help break it free. After I went backwards I went to go forwards and about when I went to get out of the little dip where the tires set it rolled back into the spot I played with the shuttle shift lever forward and reverse and it wouldn't try to go, I tried all gears and nothing. There is/was no grinding no burning smell. Is there something I'm missing or need to check or what is going on?
Does it have dual range? If it does make sure the lever didn't kick into neutral. Has happened to me a few times. If it has it it's a lever to the right side of the gear shift lever.
it does. Yeah that was one of the first things I checked I even took that cover off to make sure they were still connected.
