530 Case-O-Matic Radiator
Thank you Loren and Brad for information on the 1030 exhaust gaskets. They are on the way.
Next item is a 530 Case-o-Matic radiator. I think this tractor was rolled or some violet incident on the right front. Although still running, one radiator mounting bolt was torn off, the mounting support cracked, the core scarred by the fan and the whole radiator generally tweaked. I think a replacement better and less costly than repair. The Case-O-Matic radiator not so easy to find on line
and I noted that the aftermarket replacements don't seem to have the little brackets to attach the sheet metal on each side. So I'm in the market if someone has a good used one or knows a source.
One option for the C-O-M cooling is to simply mount a cooler from an auto that uses a tranny cooler, in front of the tractor rad.
just sold one for 46 dollars ,,SORRY .. odd how things go ...2 weeks ago out of the blue , a guy stopped in and said , he noticed i was Case farm and wondered if i had a 530 radiator for his gasser ,.. i had one from a diesel that is questionably ok with noticeable battle scars.And it had the transmission cooler outlets . basically sold it for scrap .. i asked 75 , he countered at 50 and i accepted, but all he had LOL was 46..Sigh...good enough !.... i do not have contact info although he introduced himself as John from other side of Lanesville.. i think John,Saelies
advice for a car cooler will work well at the very least a 20 ft
coilof hose might work in front of the radiator .
Seems like the one with the transmission cooler is really hard to find and even a good repairable one would be worth more than you got. My International tractors have a separate cooler in front of the radiator but I don't know what pressure Case runs through this loop. The hoses and filter body are all high pressure. I'm in California where Case was not quite so common. Think I may at least get a quote on repair of the old one but that bottom mounting bracket is all torn up and if replaced has to be in just the right place.
Not sure if ones from 530 ck or 580 with tourque converter drive wouldn't work. Check this out on eBay.
Item # 352696038553
