530 parts question
JohnMoore
Gas engine, took oil filter off also the bracket that oil filter screws onto that bolts to side of engine. What is its name? I need a new gasket and cant find one, also, can you replace oil pan gasket by just dropping it till it hits mounts? unable to take rear mount and front end loose at this point..but have about 2 inch space by dropping it as far as it will go.
Pic is for 1960-1964 530 Ag & Utility tractor. If this is your oil filter assembly, the part the filter screws into is listed as a "Bracket - filter mounting". The original p/n for the gasket G46854. That p/n may have been changed if it is even still available from Case. I would just make a gasket out of 1/32" bulk gasket material from any auto parts store. Don't know about dropping the pan.
Joe
Yes that's it, I need the gasket in that picture. That also narrows down the year model tractor it is. I just inherited this tractor, trying to get her going. I see no numbers on dash panel to track, entire gauge cluster is gone.
Where can I get that gasket and oil pan gasket? Thank you
John Saeli said he stocks the oil filter bracket gasket, I don't doubt he can come up with a pan gasket kit also. He stocks a lot of Case parts and you won't find a better or more knowledgeable seller.
Website http://external_link.com/
Joe
Apparently part of this post has disappeared. John Saeli stated that he stocks the oil filter bracket gasket. I don't doubt that he can come up with a pan gasket kit also. You won't find a better and more knowledgeable seller than John.
Website link: http://external_link.com/
