530 water pump
G. Austin
I am wanting to replace the seal and bearing in a 530 water pump. I have repaired several new generation and later pumps but the two cylinder pumps are configured differently. I know that pumps are easily destroyed if they are not pressed correctly. Does anyone have experience with these and know the correct sequence for disassembly and reassembly and is there any easy way to remove the retainer clip that has not been removed in 50 years?
when I tear those apart I put 2 flat bars under the pulley and press down on the bearing. I can't remember which snap ring is in that pump. If it's a wire in the side of the casting just burn it out with a torch or once in a while you can smack the bearing with a hammer and work the wire out (has never worked for me.) If it's an internal snap ring above the bearing cut a notch in the top of the casting and turn the ring with a screwdriver until you can knock it out with a punch or chisel. Next turn the pump upside down and press the bearing out.
Good Luck
Kevin
I do a lot of water pumps, and these are the orneryest ones to do, I made a puller to remove the pully first then the snap ring ,then the brearing, these old castings won't take a lot of extra press pressure,and they don't lay on the press bed very well, it,s easer to re-build an 8640 pump than a two cyl.pump..
The hardest part is getting a stuck retainer out.
Clean the retainer area really good so you can see if the groove is centered on the opening. If not the bearing may need to be moved in the direction that allows it to line up. When this is off it pinches the retainer ring. Soak with penterant and carefully try and work the retainer out. I have allready stuck a wire in from the other side and got broken ones pushed out.
The rest is easy if you have a press. One those later 2 cyl. that bearing will come out either way. Once everything is properly cleaned up and neverseized you can about push the new bearing in by hand.
A new impeller is a good investment as the seal wears a groove in them. At the least put the old impeller in a lathe and resurface that side of it.
Once in awhile an old impeller doesn't press fit tight enough back on the bearing and can walk off. This is why I like NEW impellers, but the last time I priced the 530 one it was VERY expensive.
I agree those wire retainers can be nasty to get out,and the older bearings will only push out one way ,away from the seal, when I rebuild bigger pumps I put a new hub on for the fan mount, I heard a story about a freshly rebuilt one sucking off the shaft from fan draught and going into the radiator,( and you know who would be held responsable)...not a chance I want to take,
Away from the seal would be the safe way to start.
I'd have to double check. I wrote it in my books and I also think I still have an old one laying around the shop with the bearing,seal,and impeller popped out all intact.
To Mike M
You were dead on with your info. My clip was so rusted and brittle that it broke even though it had been soaked in penetrating oil for a week and I made a puller to fit down in the throat of the clip. I drilled a 0.125 hole down to the hidden end of the broken clip and pushed it out with a 1/8 punch with a step ground on the end.
The seal surface on the impeller was nasty. (JD Parts prices this at $160.00) As you suggested I cleaned it up on a lathe and polished the surface.
After I clean up the housing the pump will be ready to reassemble. It looks really straight forward from here but let me know if there is anything unique to these pumps that I should be aware of.
Thanks Mike M for your help.
Those are as simple as it gets.
You are to press the impeller on so that no edges stick above the gasket surface or some spec. below ? I can't remember exactly for sure. Even the I & T books should have this info. I go a little farther on the ones I resurface to make up for how much I took off as the seal does need tension against it. I put some grease on the face of the seal to prelube it where it rubs the impeller. Don't know if this is good or bad idea ? but they seem to hold up for me.
