5310 power beyond
Traviss
Have a 5310 that I m going to put a dual directional spool valve in the power beyond circuit. So it will be a 4 port 3 function valve with a spool designed for a hydraulic motor. Tractor has three plugs that you use for power beyond. Circuit A is sump return. Circuit B is return for excess flow. Circuit C is pressure. So circuit c gets hooked up to p on directional valve. And I was going to hook up circuit B to exhaust/return on directional valve and just leave circuit A blocked of like it is now. Will this work? Will this create to much heat running hydro motor? Thanks.
