535 frame hydraulic plug leaking
kkl
Today was only the second time I started my 535 LTB (successor and nearly identical to 4500) and noticed a new leak coming from the [i:1b5b33f833]driver's side[/i:1b5b33f833] frame hydraulic plug. I'm pretty sure it wasn't leaking last year, but there is a decent size oil puddle where it was parked, in the area of the plug. I tried tightening it as much as I dared, but it's still leaking.
I'd like to know what I'm going to do before removing the plug, because I know from past experience that I'm going to get a high volume of oil shooting 5 feet away and it's going to make a mess, and I'll lose way more oil from removing the plug that I will from the leak. So, does anyone know what the problem is likely to be or how to fix it? I believe that the plug is part #191858, 81903566, or 273916, a 1-5/16/12 hex plug. I'll probably just try replacing it if there aren't any other ideas here. Thanks very much.
You can always take a hose off of a convenient cylinder and use the relevant valve to direct flow from the hose into 5 gallon pails until most of the oil is pumped out of the reservoir. The plug probably needs proper sealing, tape or dope if it's tapered pipe thread, or a new o-ring if it happens to be ORB.
(quoted from post at 15:10:33 02/16/14) or a new o-ring if it happens to be ORB.
I found an interesting website that shows exquisite detail about [u:f285ad5761]this part[/u:f285ad5761]. Here's a sample:
[code:1:f285ad5761]
MRC Parameter Characteristics
AAJD Thread Class 2A external
AAJF Thread Direction Right-hand external
AASA Thread Length 0.620 inches nominal external
AASU Head Height 0.500 inches nominal
ABHP Overall Length 1.120 inches nominal
AHNC Connection Style Plain
AJFC Body Core Diameter 0.873 inches nominal
AJFD Core Depth 0.930 inches nominal
AJGD Head Type Solid
AJGE Body Type Cored
CBBL Features Provided O ring
CMLP Thread Quantity PER Inch 12 external
CQJX Nominal Thread Size 1.313 inches external
MATT Material Steel overall
STYL Style Designator Plug, machine
THSD Thread Series Designator Un external
[/code:1:f285ad5761]
It looks like it does have an O ring; must be too smashed to be visible. I think I'll just buy the whole plug for $9.07 through CNH. Thanks.[color=blue:f285ad5761][/color:f285ad5761]
