544 international
Hi Pete, does it have a D-239 Diesel engine with Bosch injection pump?
Is it leaking Diesel into the crank case?
D-239 was used in 574,674,684,685, newer models 695 have a newer version of the Bosch Injection pump.
No its not leaking fuel in the oil. It is a Bosh pump, i had pump rebuilt adout a year ago and the had to send it overseas somewhere, when it came back it would never start withouh either, now it won"t start, and it is a d239 engine. Thanks
Hi Pete, those Bosch pump are usually very good as long as the fuel is clean. Re, hard to start requiring ether, I would suspect that the injection pump timing is to slow. As for not starting now are you sure the injection pump is getting a good supply of fuel and the pump doesn't require bleeding.
Crack an injector line at the back of pump to see if there is fuel being pumped to the injectors.
BE CAREFUL not to come in skin contact with the high pressure Diesel fuel.
JimB
JimB Thanks, I found three timing marks on the gear, tried all three none seme to help with starting, after i finally got tractor started and let it run and really warm up all bluish smoke cleared up at the mark i have it set at now, but still have to ether to start, I'm starting to wonder if i may have some weak injectors.
Hi Pete, did you remove or loosen the cap screws out of the injection pump drive gear? I still think it is timed to slow. I am speaking from experience from my brother loosening the cap screws to remove the Bosch injection pump on his 454 with a D-179. The engine will be hard to start blow lots of smoke and coat up the exhaust system with oily unburned fuel. When I corrected the timing on my brother's 454 and we took it for a test drive, it was like the exhaust system was on fire.
When warmed up the D-239 should start in less than 1 rev.
Send me an email at:
[email protected] and I will email you the procedure to set the static injection pump timing.
JimB
