Having an issue with a Farmall 544 shifter. Trying to move or remove the gear selector dowel pin
(round pin) on the cross shaft above the battery area. The pin has somehow worked it's way
partially out and you can't shift through neutral to the 2/3 or4/5 gears. The pin is in the R/1
quadrant currently and looking up from the battery compartment you can see the end of the dowel
pin is about flush with the surface of the cross shaft. Tried to pound it upwards with a punch in
an attempt to knock it out altogether but it seems to ether be stuck very tight or is hitting
something above. Very poor access to perform any work on it. I thought about drilling it out
hoping I could then just pull the cross shaft out but that pin seems very hard and I fear messing
up the cross shaft. It appears there is a hydraulic priority valve above the shifter gate area
behind the dash, if this valve were removed, would it be possible to get a punch in there and
pound the pin back into position or remove it? I've searched various forums and while this seems
to be a common problem on the 544/656 tractors, there isn't much for a solution ever offered.
Any suggestions on how to get that dowel pin moved so it's centered again? Thanks!
