Moline_guy
On a 544B loader is the pump on the rear of machine that is driven direct from the engine using oil from the transmission? We went to replace a line under the seat today and figured the trans was by itself and the hydraulic tank supplied both pumps for the loader and steering. The way it looks to me the pump in the rear must take care of steering, brakes and grab fork, and the pump driven off the transmission must just take care of the loader. So both filters down by the pivot point must be for the rear pump and the filter in the hydraulic tank is the trans driven pump? The grab fork control was added by some one, we run ATF in the trans and Hytran in the hydraulic tank. Sure are alot of lines running back and forth compared to our other loader.
