CARLR
I have to replace the clutch in my tractor. Can someone explain how to do the Z split. Also, the process of removing the clutch and installing. Do I need to get a new bearing also? I have herd that the front half of the tractor is a little tricky in balancing. How do I jack the front up. I have a roller jack for the back and a roller jack and three bottle hydraulic jacks for the front. My email is [email protected] .Thanks for your info.
55 Oliver as in a super 55 or is that the year of the tractor. Knowing for sure what you have helps use help you.
Just a couple of examples. I own an Oliver S88 that is a 1955 and to do the clutch on it would be a lot different then doing one on a Super 55
