I am trying to replace the friction disc on the draft control lever on my 1955 and need to know if the o ring that seals that shaft can be replaced by removing the support mount behind the disc, I may need to add some heat and if I do that o ring will need to be replaced but I am not sure I can get to it without tearing into the hydraulic housing.
Common sense dictates that o ring should be able to be replaced but I am finding not much common sense was used in designing the 1955
