I have had my 550 a month or so and still trying to figure everything out. It does not want to go over 1700 rpm and it does not run as smooth as most. I have: new plugs, new wires, valve adjustment, carb kit. It idles nice, it seems to run worse the warmer it gets.
The tractor set for 2 years. From the color of the oil and the cleanliness of the head it would seem it at least had a valve job before it quit being used.
I have not yet, done the timing and have not yet replaced the power valve on the carb. It is a type C marvel with that adjuster in the bottom and does not come with any carb kits I have found. Have not done a compression check.
I noticed a few things while taking it apart. The down draft tube has something that looks like a check valve. Tractor is a 64" is this some sort of PCv (picture enclosed). Tractor has electronic igniton. I have enclosed a picture of the ballast resistor. The post at the top end is a bit loose? is this the issue?
Also the alternator has a 2 spade connector on the side. Does this mean i could get an electric tach for it?
