550 Oil Leak
RustyCase
OK Oliver guys, On my 550, I replaced the oil seal on the PTO shaft hub to address an oil leak. After reassembly Its still spotting the floor and on closer inspection the oil is coming from the PTO stub shaft receiver. How is this oil getting into the receiver and what is the fix?
There is an o-ring that goes inside of the adapter you show in your picture and the long PTO shaft inside the transmission, it is probably hard or damaged and will need to be replaced. You will have to drain the frame gear oil and pull the flange back off to replace it. The o-ring is number 10 in the image. The AGCO part number is 70925639.
