JimFord555
New torque plate cantered and mounted to a freshly rebuiltrebuilt torque converter at a local one man shop called Island Torque Converters in Victoria BC I was very impressed with.
I needed a new bushing in my transmission hydraulic pump housing and as ford calls for the whole pump to be replaced I couldnt find a replacement bushing
TC guy got a new bushing intended for a Ford atx transmission out of cars like ford escort from the 80s. pressed it into the housing in 5 minutes
Using my dial indicator secured to the block and reading the torque converters rear hub by rotating the flywheel by hand. I continually removed the TC and re installed it one bolt hole over. I was getting measurements like .060 - .015 out. Until I hit .003 . Wanting to stick with this I removed the bolts one at a time applying high heat lock tight and torquing to spec. After re checking Im at .010
Engine Install:
The manual calls for the TC to be left in the transmission and mated to the flywheel after the engine is bolted up to the transmission housing. It says to start the bolts then turn the engine over a few times for proper alignment. This is done through a small access plate on top of the transmissions bell housing.
Bern has said he prefers the engine to be mated to the trans with TC/TP mounted to the flywheel already and uses dowels for alignment.
My plan:
-engine suspended by a neighbours excavator from quite high to allow a long pendulum effect making manoeuvring easier.
-2 slings under the oil pan at each end of the engine attached with a chain jack each to a common point for front to back angle adjustment.
-4 threaded dowls will make alignment easy and avoid damage to the new pump seal
As this is not the procedure in the manual what is an acceptable reading for out of true for the TC shaft ?
Should I loosen the TC bolts to allow a small amount of play and rotate the engine before tightening to spec through the access hole ? Or is this defeating the purpose of this method
Here is a video of where Im at
https://youtu.be/BEj7PumaWS4
Any advice is much appreciated
Engine Install:
My plan:
