55O LEAKING TRANS OIL
TIM COLLIE
1958 OLIVER 550.LEAKING TRANS OIL OUT SMALL WEEP HOLE UNDER BELLY.IS IT THE FRONT TRANS SEAL.HOW MUCH TROUBLE IS IT TO SPLIT TRACTOR AND REPLACE?IS THERE ANYTHING I CAN PUT IN THERE TO SLOW IT DOWN SINCE THE SEAL IS PROBALY HARD FROM SITTING UP?WHICH SERVICE MANUAL WOULD YOU RECOMMEND?
I HAVE READ HERE ON THE FORUM THAT TO CHECK TRANS OIL LEVEL YOU SHOULD REMOVE A SMALL PLUG ABOVE THE PTO SHAFT IS THIS RITE?THE 550 HAS A LARGE PLUG ON TOP OF TRANS WERE YOU FILL IT I POURED 5 GAL OF GEAR OIL IN BUT DID NOT COVER GEARS.COULD IT BE OVER FULL?
5 GALLONS IS THE RIGHT AMOUNT IF IT WAS EMPTY. THE TEST PLUG IS JUST ABOVE AND TO THE LEFT (I THINK) OF THE PTO SHAFT. MINE IS A SQUARE HEAD PIPE PLUG. THE FLUID SHOULD BE LEVEL WITH THE BOTTOM OF THE PLUG HOLE, SO IT SHOULD JUST BARELY SEEP OUT OF THERE WHEN YOU REMOVE THE PLUG, IF IT COMES PURING OUT IT IS TOO FULL. GOOD LUCK
I have two Super 55 rear ends apart right now.
Before you start get a good manual and look the job over. The origional Oliver service manual is good and gives you a couple of ways to go about the repair. There are some areas to be careful.
If you get in and out with only replacing a seal you must be living right.
