I REWIRED THE IGNITION SWITCH ON THIS 560 DIESEL WITH A 3 LEGGED SWITCH NOT REALIZING THE ORIGINAL WAS 4. I CHECKED IT AND BOTH THE
AUX AND IGNITION WERE HOT WHEN THE KEY WAS ON. I THOUGHT I COULD PUT THOSE TWO TOGETHER AND MAKE THE SWITCH WORK. THE STARTER
SWITCH WORKED AS IT SHOULD. IT WOUULDN'T START AFTER BEING RUN SUNDAY, THE GLOW PLUGS WORKED AND IT IS 80 HERE TODAY. DURING TRYING
TO START IT AFTER CHARGING THE BATTERY THE SMALL WIRE FROM THE GROUND TO THE FUEL SENSOR ON TOP OF THE TANK GOT REAL HOT. DID I
MESS UP WITH THE SWITCH OR IS THIS A SEPARATE PROBLEM. THANKS FOR ANY HELP.
