560 fan bael
recently picked up a 560 that was partially apart. the fan was off of it and there is not a belt with the tractor. what size belt does this tractor use
also is there a second belt that runs the generator? if so what size is that one ?
thanks
Obvious answer: They're the sizes of the belts that the friendly CaseIH parts man gives you when you walk up to the counter and say, "I need a set of fan belts for a 560 please."
I was able to look this information up on partstore.caseih.com. You can take these numbers to NAPA and have them cross reference.
Fan belt is IH part 403348R1 (old number 149635R1). The online parts book shows this belt also for the generator and water pump on a gas engine.
Diesel water pump/generator belt is part 385738R1 (old number 316250R1).
huh, fan blade or complete fan? you said fan was off. getting totally confused now.
but common belts and no problem getting them anyplace. average 20.00 ea.
Just take a string wrap from one pulley to next measure the string and go buy that length belt parts store leave itself some adjustment
