560 Farmall loader hook-up
I am trying to put a loader on a 560 and have 3 controls levers. 1 is for the 2 point on the back. There is 2 hose hook-ups on each side of the tractor and 2 hose connector on the back, which one do hook up to ? I am looking about single or duel cylinders. Thanks
the ones to the front are just another set of lines from the same place as the rear. So if you have a valve you don't use much you could use it and tie the lever back so the loader would work with the other valves that come with the loader.
If you plan on using the tractor's levers to control the loader, then connect the boom hoses to the ports on the left, and the bucket hoses to the ports on the right.
If the loader has its own valve, quick-n-dirty solution is to pick one set of ports, connect the valve to that, and bungee cord the corresponding lever to make it work.
