(quoted from post at 06:16:27 04/25/19) I have clean the bowl several times and disconnected the fuel line from the carburetor and drained the line.
I'm not aware of the fuel inlet filter. Is it a part of the carburetor? except for the bowl there is no noticeable filter.
Thanks in advance for your input
(quoted from post at 07:52:35 04/25/19) You unhooked the line and "drained" it but did you actually observe good fuel flow over an extended period of time?
In order to verify flow, you need to let the tank drain into a catch can or bucket for at least a solid gallon, and during that time it must flow a solid consistent stream of gas.
Also, cleaning the fuel bowl is just one part of the carburetor cleaning process. A new carburetor is a waste of money.
