I have a 560 that won’t lift a 10 ft disc. It could be the cylinder on the disc, the pump, the valve or something plugged.
Can someone explain the how the 560 hydraulics work. I do not have a loader. The fast hitch has been removed and plumbed back into itself with a hose. I have couplings on the front side of the valve on both the left and right side. There is three hydraulic levers. There is some linkage by my left foot that you need to fiddle with or the pump whines to the point you go crazy.
I would honestly disconnect everything except 1 remote and then plump that to the back. It just looks rather complex for something that should be fairly simple.
I haven’t troubleshot anything. I know there is a screen that needs checked, a valve spring and steel ball, and some other items just wanted to understand what it all is for before I tear into it.
