560 M -- PULLEY DRIVE THE SAME?
JUSTIN TIME
DOES ANY ONE KNOW IF THE PULLEY DRIVE OFF OF A 49 M WILL WORK ON A 59 560 WHEATLAND. THE PULLEY DELETE PLATE LOOKS THE SAME AND IT THE PARTS CATALOGS THIS PLATES FITS BOTH, BUT WILL THE PULLEY DRIVE ACTUALLY WORK? THANKS FOR ANY HELP
It will fit and operate. The shifting lever that connects to the operating rod that you move to put the belt pulley in gear will be on the left side. I believe the M setup is on the right side.
The lever could be rewelded 180 degrees from its current position. Perhaps the changeover could be done from the inside by rotating the shifting fork. Dunno. I never have disassembled the BP shifter.
