Absent Minded Farmer
- Location
- Gehl Country, Wis.
It is cold out (34ºF) & I don't have any form of heater on it. Not going to use it much when it's cold out, but when I'm out of running gassers, it's nice to have something to move equipment with in the fall.... like now. The idea of a second battery sounds good. I'll take care of that when I get some spare scratch to do it. The timing could be off, too. Might have air in the system. The secondary filter weeps from the bolt. There's a new washer for that around here somewhere. Just have to find it. Any other ideas as to what could be making it a bear to start? I did notice one anomaly. I use the glow plugs for about a minute & a half. Takes a few tries with the starter to get it going & the throttle has to be at low idle. The exhaust it thick & black at that point. Once the engine catches, I have to let off the plugs until the exhaust turns white. Then I can hit them again to get it to fire on all cylinders. Usually about another 20 seconds. Then I can notch the throttle up to 1200 RPM to warm the engine. Do those symptoms give an idea as to what's up?
Mike
Mike
