Trying to figure out problem with hard to get tractor in gear(grinding). Clutch does not slip but does let out at the top of petal travel and T/A shifts and works fine. The only way it will go into gear is I
have to adjust the T/A to where it rides against the T/A clutch fingers. Does this sound like a main clutch or T/A clutch problem ?
I would guess a main clutch issue. If you throttle tractor way down and see if that will allow you to shift it into gear.
Let me put it to you like this , First off there is NO clutch brake to slow/ stop the clutch from turning when you stomp down on it and the gears will turn for some time . Now like Jim said you may have a pilot bearing problem , you may have a flywheel problem where the face of the flywheel is not flat and the disc is lightly dragging , your transmission is not synchronized so there are no blocking rings o act like a small brake to allow no grind . You should have between 7/8 to 1 inch of main clutch free travel . Now to to extensive field testing of said tractor i ma sure you have lots of ware at all points in the linkage and you have to deal with it and learn to adjust around
