560 Wheatland
Jim James
My 560 International is stuck in one of the forward gears. I can move the gear shift, but not get itout of the forward gear it is stuck in. I need the tractor pretty bad. Anyone have any ideas on what to check for and how to go about it?? Any help will be very much appreciated.
(quoted from post at 18:10:34 04/14/08) My 560 International is stuck in one of the forward gears. I can move the gear shift, but not get itout of the forward gear it is stuck in. I need the tractor pretty bad. Anyone have any ideas on what to check for and how to go about it?? Any help will be very much appreciated.
Remove the three bolts that hold the shift lever to platform. Move the shift rail that is not lined up with the others until they all have the slot lined up. Reinstall the shift lever. If it continues to happen you will need to build up the end of the lever where it gets worn.
