565 4-16 oliver plows
2 stroke
Hey fella's I've got a question about set of Oliver 565 4-16 semi mount plows. Can you add a moldboard to make them 5-16 plows, and if not which series of Oliver plows can you add a moldboard too?
Yes you can add a bottom to a 565 as long as the tail wheel bolts by the back bottom. I have a 565 5 bottom that is a 4 bottom with a bottom added and a 4 bottom 565. A bottom can be added just needs the longer control arm for the tail wheel and the a longer lift pipe. Bandit
the oliver pipe plows had a single or a double add on. i currantly have a 7 witha double to make 9bottom
