567 baler fault code
Having code e4 31 showing up on monitor just bought baler first time using it didnt get any manuals with it gonna order one Monday but anyone that can look up in manual would be appreciated havent found anything on google either
You can down load a copy of the Operator's manual at no cost from the JD Ag Technical Store. It won't make a direct link to the manuals so you will have to do the Equipment Publications search to find it. There is are serial number breaks so they show three 567 groups based on serial numbers. From a quick look at them I didn't see any Error Codes listing in the early manual. The other two later ones had Error Codes listed but neither showed e4 31. There may be more codes in the Technical Manual, but that is a purchase.
Here is the link to the Ag Technical Bookstore: JD Ag bookstore
(quoted from post at 17:15:15 08/22/21) Google can be your friend. What I found E4 31 is supposed to be over-size bale switch always open
Could be, in the manual that description showed as code e4 03 in two of the 567 manuals, but it was out of numeric sequence compared to the others so it could be a misprint in the manuals.
Here's a list of codes for some models of JD rd balers
