'57 Farmall 230 with hyd. pump problem....
Bobinva
My 230 has developed the "empty hyd system/overfull crankcase syndrome...I know there are about 4 O-rings and a oil seal between the pump and the cam-gear driver which leads directly down to the crankcase...what's the deal to replace the oil seal/O-rings...to hopefully stop the "flow"....thanks Bob in VA
I just finished replacing O-rings and the shaft seal on my 3414.
I found the seal kit at bates international. Take pictures as you take the pump apart so it goes back in order and keep it clean.
This stopped the oil to the crank case on mine. You-Tube has several videos of taking hydraulic pumps apart. Just type in "how do you replaces seals in hydraulic pumps" and it should give some selections to start with. Darold
