574 international injection pump
Yes. The gear will remain in the housing. Time your pump before you remove it-if I recall correctly, the keyway will be at 10 o'clock. Be careful not to drop the key- I usually lay/pack a rag under the gear. Mark.
Hi Jeremy, be sure to set the static timing and mark everything before removal. DO NOT LOOSEN the bolts on the drive hub only the big nut on the drive shaft.
IH recommends a special puller to remove the gear from the drive shaft.
You can find the manuals for 574 at the link below.
574 manuals
