574 won't shift into 1st gear
Kirk A
I have a 574 utility that has not had a loader on it. I can not shift it into first gear in either low, high, or reverse. I have tried to drive it forward and in reverse in second gear to try and get it into first but it acts like the there is something not aligned or someting that will not let me shift it up into first. I can shift between 2nd, 3rd, and 4th among the other ranges, but just not into first. The linkages are not broken, damaged, or jammed with anything that I can see. I would greatly appreciate and suggestions or ideas of how to solve this. Thank you!!
Did you try to shorten the rod from the lever to the shift arm? Ours has always shifted into first ok. Sometimes it does it better than others.I probably need to adjust it some too.
