580 Ck Injector pump leak
R O A
Everything works fine and the machine is runnig great, but has developed a leak on the injector pump where the throttle arm comes out of the body-on the exterior ( not engine ) side. Hard to find info and obviously I don"t want the expense of a rebuild. Couple of questions. 1976 machine- has a different number than the manual- dbgfcc 435 3aj. NOT 431. replacement injector pump? anybody know will a seal kit fix this?
There is a clip internal to the pump that keeps the throttle and shutoff levers from sliding out of the pump. It also serves as a shutoff lever, to remove the shafts you must first remove the top of the pump, looking at the shafts you will see the clip sticking up above the shaft, once removed, the shafts will slide out easily and o rings can be replaced. One note, thoroughly clean the whole side of the engine so as to minimize the chance of dirt getting into the pump.It should be able to be done with the pump in place on the engine.You can get the o rings and the top cover rubber at any Stanadyne service center. mEl
You can buy the entire seal kit for around $12 and it will have the throttle shaft seals you need, including all other o-rings and seals. Shaft comes out in two pieces and each half gets one o-ring and one teflon washer.
If your pump has manual shutoff, there will be an extra shut-off clip inside that you have to remove. If electric, it won't be there.
Complete seal kit is Stanadyne # 24371 or aftermarket Spaco U24371 $12.10
www.usdiesel.com is a dealer in Fort Worth Texas is a dealer and will ship to anyone.
800-328-0037.
I'm curious about that pump number. The seals are all the same, so the number doesn't matter. But, the 188 diesel usually has a pump with .31" pump plungers , and your's has .35". Do you have a 188 or a 207?
Like I say, it doesn't matter in regard to the seals, I'm just wondering. Seal kit is the same for all D and DB Roosamaster/Stanadyne/Hartridge Tool pumps.
Thanks you guys I did not intentionally take this long to get back. I thought I had marked to get email notification of a response, guess I didn't. I appreciate all the help. My diesel mechanic brother who is unable to help , scared me pretty bad about working on this. From what I'm hearing this is not going to take a full rebuid. Just replace the seals in the pump top, around the throttle shaft? Just want to make sure on that. As to whether I have a 207 or a 188. I thought it was a 188, but how would I verify that?
My brother is a diesel mechanic ( too far to help) but he scared me pretty bad about doing my own rebuild on this. Timing and pressures and such. But from what I'm hearing and if correct this leak can be fixed with only a portion of the rebuild seals / o rings? That the kit has the o rings and top cover gasket in it? and I don't have to get into the guts of the injector pump to fix this leak? I don't even have to take it off the tractor? Just want to make sure. As for the number on the injector it is correct. I'm not saying it is the original injector. I've always assumed a 188 and any repair or parts person has ,too. How do I verify if a 207? If I can fix this for undre $15 andtime vs $300- $600 for rebuild . AWESOME. Thanks, too did I say that?
