580ck questions
Just a few questions, backhoe rear bucket hydraulic cylinder seal kits or rebuilt kits and stabilizer rebuild kits. There are no numbers on the cylinders, so how do you know which seal kit to order since there are 5 different set according to case dealership I spoke with today. The coolant temperature sending unit with one wire 3/4" is not available from case and napa didn't have it either. any suggestions?
thanks Jerry
Good evening Jerry just a shame in today world how incompetent parts guy can be ,there is no such thing as
five different cylinder type for your 580 CK machine . If he would do his homework to help customer instead of
flushing them because it is old machine world would be a better place. First of all if you cannot find the
sender unit I do have a bran new one from Case .second I will tell you to check for this
One stab cylinder has what is call a split seal on the outer part of the gland whereas the newer model has a
solid seal , same thing for the Bucket hoe cylinder . The price on these seal kit is getting wacky since Fiat
owns Case new holland and IH and whatever .If your cylinder only leaks on the rod I would suggest to buy only
the seal inside the gland G107922 for stab cylinder with 1-3/4'' rod or G107921 for stab with 1-1/2"" rod.
since this is not a new machine For the Bucket hoe cylinder you need for Cylinder with 1-3/4 inch rod G107922
or with Bucket cylinder with 1-3/4 inch rod you need seal for gland G107922 and with rod of 2'' G107923 if you
need the kit let me know the size of your rod on each cylinder and I wll give you the kit number you need. my
e mail is [email protected]
