Masterofnone
Hi guys, had the boom hose burst on my case580SL and I need to replace it. I have a few questions:
- is there a special wrench to take the hydraulic fittings off the valve, or just a stubby?
- there is a tapered steel shroud that goes around the hose where the clamp block squeezes the hoses. What is that called? I can t find them anywhere.
- is it worth putting quick connects on so that if the hose pops again it s easier to change, or is that just adding more failure points?
- The hoe was locked in place when the line burst. Is there a trick to unlocking it with no line pressure? Best I can think of is backing it up against a tree to push it back enough to unlock.
Thanks for any help you can provide.
