Daniel Burks
Ok, I have flat top fenders
The relay sounds like a good idea, just make sure it is rated for the amperage and for constant operation.I may have figured it out. The fuse holder is melted behind the fuse, it shows good on the fuse side but nothing leaving. Thanks for the help! I guess I’ll add a spade fuse holder or maybe add a relay since it calls for a 35a fuse.
Thanks! Could you possibly email this to me? I cannot open it fully.Good looking 584, it does have some IH Louisville, KY, USA options, so my wiring diagram may not be 100% compatible.
Fuses 3 and 5 are used for the lights, Fuse 4 appears to be a spare.
Good luck
Jim
I would recommend you contact Jim through a Direct Message to share email addresses rather than post them on an open forum. Click his username by his reply and you’ll find the option there.Thanks! Could you possibly email this to me? I cannot open it fully.
Thanks for the advice. He messaged me.I would recommend you contact Jim through a Direct Message to share email addresses rather than post them on an open forum. Click his username by his reply and you’ll find the option there.
