DJO
What pistons are used to put a 800 crank and rods in a 585 block to run diesel? Is this possible economically? Thanks
The crank will bolt in, but you cannot use the 800 connecting rods as there is not enough room for them to clear the camshaft. If you are going to farm with this tractor, then it is not worth it. If you are going pulling with it, then it"s up to your pocketbook. If you are pulling, you have some choices, but none of them are cheap.
