(quoted from post at 19:18:30 12/08/18)
So whuts a hydrometer gonna tell ya you don't already know...
Ell , I don't know , but I got two of them !
I have used them on known good fully charged batteries and they said they were not good . I get to use the City's Fluke amp clamp meters which are dead on accurate , so that helps . There is a temperature part of the equation also . I am saving money for a good carbon pile load tester , not that I really need one anymore , just want one . I have never heard the guy at the parts store check a battery and not say " You need a new battery"
I got one of them big roll around battery chargers 6v/12v 2/10/40/200 amp . The meter always shows in the green even on a battery that does not have enough power to crank the motor ??? and on the 200 amp start mode the meter never gets over 40 amps ??? But it gets it going quickly .
I read that the acid doesn't boil out , just the H2O so distilled water is all you need to replace . Also read that different manufactures used different levels of acid / H2O . I have not looked very hard but wonder how to test the acid percentage which is a big factor when using a hydrometer ???
Sold all of the farm trucks and hobby cars and stuff so I only use 4 batteries on the farm now . 12.5 volts + charged and all is good . When they die , which is at a lot younger age than the way they were made , I just buy a new one , which is what they are trying to get me to do anyway .
I did buy a small electronic amp / pulse charger / maintainer for the 4dlt tractor battery if I am going to let it set for more than a week . And I even bought a couple gallon jugs of distilled water for 97 cents at wally world , still burns my behind to pay for water .
I don't know if I want to use a rubber pad heater , magnetic heater , freeze plug , or hose heater , of just pointing the 40k btu kerosene at the side of the block under the intake manifold . The battery sure likes when I preheat the motor / fuel .
I figure that just like the wipe in go rags , If I actually listen to the pros and cons and discard the wife's tales the real answers will come out . Of course I am in no hurry since I am not having to stand behind my work to a paying customer . My chit breaks I can go to plan B and nobody cares .
